Since the version I have can not filter a cell count I tried to delete the data in some cells. It acted like it was working but nothing is deleted. Is this a bug in version 7.2.3 patch 002?
Thanks.
Bill
Thanks.
Bill
2011 Camaro 2SS/RS L99 RJT
VMax Ported RJT Throttle Body
Gorilla Wheel Lock System;
Just be alittle patient Bill. I don't know if that is a bug or not as I haven't tried it in your version. I know Paul is working hard on a stable release.
I've used the+ keys to delete selected frames successfully in the 7.2.3 pre-releases.
Does that work for you?
Andrew
EFILive Crew
I tried that and the number is still there.Originally Posted by Tordne
Bill
There is a bug that does this:
Delete a single frame from the log file, the frame is deleted but the frame count is not decremented. So all the frames shift left one place and the last frame gets duplicated in the second last and last frame positions.
If you are trying to delete the last frame - you can't.
IIRC if you delete n frames then the frame count is only decremented by n-1.
It is fixed in 7.2.3. which should be available available this weekend.
Great, I will install it ASAP.Originally Posted by Blacky
Thanks.
Bill
