Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Engine Oil Pressure PID
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    Default Engine Oil Pressure PID
    During my upgrade to the Beta BBL that just came out I followed the procedure to upgrade to the latest 7.5 software. I was previously using V7.4.2.
    Then I upgraded to teh V7.5.3 software. I noticed the engine oil pressure pid name has changed in the Scan Tool, and is no longer supported for my controller type.
    I have a 2004 GTO PCM using OS 12587604.
    The PID I was using for Engine Oil Pressure in the 7.4 software was called GM.EOP and I was able to log the oil pressure. In the new V7.5 Scan tool the PID looks like it changed to GM.ENGOILP and is not supported. For me this is a critical PID to log since I road race my car and oil pump starvation is an issue I watch closely.
    Is there anything I can do to log engine oil pressure as I did with the V7.4 software?
    Edit: I just checked the PID description file to see if GM.EOP was available for BBL. I did find EOP in that LS1B_M_PIDs file. I was able to log the parameter in BBL. However when I toggled from metric to imperial units, EOP would remain in kPa even in imperial unit mode.
    You can change the units by specifying the units and conversion factor in the *PCU section at the end of the Options.ini file.
    Here's an example of the entry you would need to convert kPa to psi:
    Code:
    ;   PID      Caption  Prec Units Op    Factor        Offset
    PCM,EOP,     OilPsi,     1, psi,  *,     0.1450377377,   0.0
    Mar 2004
    Had an oil pump on an ls1 fail on the dyno today efilive would not valadate the oil pressure pid
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    So is EOP working again for our LS1-Bs via BB?? We lost it a while ago
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    Aug 2007
    Is there any way to log oil pressure via the Scan Tool software on my laptop? Please see original post for what the issue with that is.
    I'll check the engine oil pressure PID today on an LS1. And post back the results here.
    Aug 2007
    Any findings on this subject?
    Quote Originally Posted by Kevin Doe
    You should use GM.EOPS to log oil pressure on an LS1 from the PC using the V7.x.x software. EOPS stood for Engine Oil Pressure Sender and originally only returned the sender's 0-5V signal, not kPa or PSI. Now that it is returning kPa and/or PSI in the BBL firmware, its name has been changed to just EOP.
    EFILive automatically changes the BBL PID names back to their V7 equivalents so that you cna view the PIDs in the V7 software. Once V8 software is released the translation will no longer be necessary.
    The Translation table for all PIDs with name changes between V7 and BBL is in the sae_generic.txt file under the section *BBLV7.
    Here is the list to save digging around in the sae_generic.txt file
    Code:
    *BBLV7
    #BBL Name      V7 name
    ; SAE paramaters
    WO2AS11        WO2S11_B
    WO2AS12        WO2S12_B
    WO2AS13        WO2S13_B
    WO2AS14        WO2S14_B
    WO2AS21        WO2S21_B
    WO2AS22        WO2S22_B
    WO2AS23        WO2S23_B
    WO2AS24        WO2S24_B
    ; GM Enhanced parameters
    ESTDIAG        STATE14
    ETCTAC1        STATE15
    ETCTAC2        STATE16
    ETST           ETCS
    MAF_GM         MAF
    MAPS           MAP
    ACHPRS         ACP
    GENFDC         ALT-F
    TP_A           TP
    FRPS           FPS
    BBVPS          BBS
    DESTQ          DESTRQ
    EOP            EOPS
    EGRCMD         EGRCOM
    TRACTRQ        ACTTRQ
    TTQRET         SEMRET
    BARO_B         BARO
    EOLIFE         EOL
    RUNTIME        RUN_TIME
    MAFSD          DYNAIR_LS2
    EGRCLOSE       EGRPINTLE
    IDLERPM        IDLRPM
    STFTAVG1       SHRTFTAVG1
    LTFTAVG1       LONGFTAVG1
    STFTAVG2       SHRTFTAVG2
    MFFAIL1        MFFAIL
    MFPASS1        MFPASS
    LTFTAVG2       LONGFTAVG2
    FTV            FTP
    CASE           CASEERR
    CURRCYL        CKREFCYL
    FANDC          FANPWMDC
    GENLDC         GENL_DC
    IGN1CC         IGNCOIL1
    IGN2CC         IGNCOIL2
    IGN3CC         IGNCOIL3
    IGN4CC         IGNCOIL4
    IGN5CC         IGNCOIL5
    IGN6CC         IGNCOIL6
    IGN7CC         IGNCOIL7
    IGN8CC         IGNCOIL8
    INJ1CC         INJECTOR1
    INJ2CC         INJECTOR2
    INJ3CC         INJECTOR3
    INJ4CC         INJECTOR4
    INJ5CC         INJECTOR5
    INJ6CC         INJECTOR6
    INJ7CC         INJECTOR7
    INJ8CC         INJECTOR8
    O2H11DC        O2HTRDCB1S1
    O2H21DC        O2HTRDCB2S1
    VSFPDC         FPVSPDDC
    EOT            EOILTS
    FANSPD_DES     FANSPD_ACT
    TSTATE33       TSTATE02
    TSTATE34       TSTATE03
    TSTATE35       TSTATE04
    TSTATE36       TSTATE05
    TSTATE37       TSTATE06
    TSTATE39       TSTATE07
    TSTATE40       TSTATE08
    TSTATE41       TSTATE09
    TSTATE42       TSTATE10
    TSTATE45       TSTATE12
    TSTATE03       TSTATE13
    TSTATE04       TSTATE14
    TSTATE05       TSTATE15
    TSTATE06       TSTATE16
    TSTATE07       TSTATE17
    TSTATE16       TSTATE18
    Aug 2007
    I guess I should be more clear.
    When I open EFILive Scan 7.5 (7.5.4 Build 44) I do not see a PID called GM.EOPS. The only oil related parameters I see are:
    GM.ENGOILP (not supported, and described as Engine Oil Pressure in kPa,PSI)
    GM.OILTS (not supported, and described as Engine Oil Temperature in *C,*F)
    GM.EOILT (not supported, and described as Engine Oil Estimated Temperature in *C, *F)
    GM.EOL (supported, and described as Engine Oil Life in %)
    However, in BBL, I can log EOP.
    Have you tried (re)validating PIDs using the menu option: Info->Validate PIDs.
    If that does not help (probably won't if you are not seeing it at all, even as "non supported"), let me know and I'll dig into this issue deeper.
    Can you please tell me what operating system your LS1 is?
  1. LS1 Engine Oil Pressure- HTF do i log it?
    By Tre-Cool in forum General
    Last Post: September 29th, 2008, 01:41 PM
  2. oil pressure pid
    By HINDZY in forum Gen III V8 Specific
    Last Post: May 17th, 2008, 01:59 PM
  3. oil pressure pid
    By wadesns in forum General (Petrol, Gas, Ethanol)
    Last Post: December 14th, 2007, 02:27 AM
  4. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  5. Fan A/C Pressure
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: February 8th, 2007, 10:19 AM
