Results 11 to 20 of 32
Thread: Engine Oil Pressure PID
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    Have you tried (re)validating PIDs using the menu option: Info->Validate PIDs.
    If that does not help (probably won't if you are not seeing it at all, even as "non supported"), let me know and I'll dig into this issue deeper.
    Can you please tell me what operating system your LS1 is?
    Yes, I tried several times to revalidate the PIDs, but it still doesn't show up.
    My OS is 12587604.
    In EFILive Scan 7.4 I was the PID GM.EOP was available and logged in kPa,Psi. If you find an issue is there any chance you have updated software that will include a fix for this by April 11th? Just curious because I'd like to log engine oil pressure for my first track day. Not sure how fast your turnaround is or what your plans are for rolling in all these new fixes we just found.
    I will be updating the software before the end of the week. I expect the oil pressure PID to be fixed in that release.
    The GM.EOPS PID is now back in the config file, however the LS1 controller returns the value as a voltage between 0 and 5 volts. The default conversion factor and offset for LS1 controllers is:
    kPa = V*1103.125-110.3125
    or
    psi = V*160-16
    Correction, the factors should be:
    1103.125/5=220.625 for kPa and
    160/5=32 for psi.
    The offsets remain the same.
    I recommend creating a calculated PID to display the oil pressure in kPa or psi. I have not yet worked out what the conversion factor is for other controllers (i.e. Duramax Diesel).
    For LS2 applications, use PID GM.ENGOILP which is returned in kPa. GM.ENGOILP is not available in LS1 platforms, which is why you need to create a calculated PID based on GM.EOPS.
    Warning: The factor and offset shown above are calibrated values and on some controllers may be different than the constants I described here.
    The BB Logging PID: EOP, was configured to convert the PID voltage to kPa, but it cannot be configured with a constant factor and offset as they are calibrated values in the LS1 controller.
    It will be changed to return volts and renamed to EOPS - exactly the same as the V7.5.x software.
    Lifetime Member emarkay's Avatar
    So EOP is now available for what year LS1's?
    Early EFILive V5 user - Upgraded from AutoTap for DOS!
    2000 Chevrolet Camaro Z28, A4 - For occasional day trips...
    1984 Chevrolet Caprice Classic - For the family...
    1989 Honda VTR250 - For me and me only...
    ALL LS1's, except those LS1's that do not have an oil sender connected to the PCM. (i.e. F bodies). The PID is still valid on those PCMs but it does not return oil pressure data.
    Mar 2008
    Kevin -
    I'm a drag racer with a 9 sec 2000 C5 Coupe running a C5R 427 blower car. My V1 was stolen in Memphis last year at the LSX shootouts. I now have a V2and am patiently waiting for BBL to arrive. I use this on one car for dragracing! I am intrigued by the Oil Pressure PID. Do you think the signal from a 2000 GM PCM oil pressure sender "could" be used to trigger a engine safety shutoff? Your thread here got me to thinking!
    JR
    Quote Originally Posted by JR-CRUZN-C5 View Post
    Kevin -
    JR
    There is provision in the 2000 PCM for the engine to shut off due to low oil pressure. Is that what you mean?
  9. #19
    Mar 2008
    Blacky -
    Yep - That's exactly what I mean. But I wonder if the GM safety margin is fast enough to save a racing engine from catistrophic failure due to a broken or failing oil pump during a run???
    JR
  10. #20
    Can't say for sure, but probably not. I think the built in shut-off and logging of the shutoff reason is just to help the dealer pinpoint why the bearings are all munched up.
    I don't think it is there to save anything before it gets damaged.
  1. LS1 Engine Oil Pressure- HTF do i log it?
    By Tre-Cool in forum General
    Last Post: September 29th, 2008, 01:41 PM
  2. oil pressure pid
    By HINDZY in forum Gen III V8 Specific
    Last Post: May 17th, 2008, 01:59 PM
  3. oil pressure pid
    By wadesns in forum General (Petrol, Gas, Ethanol)
    Last Post: December 14th, 2007, 02:27 AM
  4. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  5. Fan A/C Pressure
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: February 8th, 2007, 10:19 AM
