Results 1 to 3 of 3
Thread: what vin do i use the ecm vin or the dash vin
    Member nycblazer's Avatar
    Jan 2008
    Default what vin do i use the ecm vin or the dash vin
    hello
    i just did a engine and ecm swap on my 2001 s10 blazer.
    just wanted to know wich vin do i use for the efi live programer v2.
    do i use the vin thats on the dashboard or is there another vin inside the program of the ecm i just swaped with the engine.
    i only have 1 vin left and dont want to mess it up.
    thank you in advance
    The VIN doesn't matter... FlashScan licenses to the PCM serial number.
    You would do these steps:
    1. full flash the PCM with the right OS,
    2. edit the VIN using the scantool,
    3. do VATS relink if equiped with VATS.
    4. do CASE relearn.
    I suppose the order of steps 1. and 2. may be swapped.
    You use the VIN that matches with the rest of your components.
  1. GEN IV .vdb tuner dash?
    By Bruce Melton in forum Gen IV V8 Specific
    Last Post: October 11th, 2009, 10:08 AM
  2. Dash pages!
    By Doc in forum Tips and tricks
    Last Post: October 25th, 2008, 09:59 PM
  3. ABS warning on dash
    By hymey in forum FlashScan V2 BB Logging
    Last Post: March 12th, 2008, 02:52 AM
  4. Custom dash in V7.5 ??
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: January 16th, 2008, 12:43 AM
  5. Setting up the dash
    By Spdfrk1990 in forum General
    Last Post: June 10th, 2007, 07:12 AM
