Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: LLY - No BBL
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Default LLY - No BBL
    V2
    FW: FSProgV2_05_15(0320)
    Controller: 04 LLY (15141668)
    Symptoms:
    Select vehicle: LLY
    Display Data (F2)
    Nothing happens.
    Record Data: Screen goes to “Please Wait” then back to “Data Logging” Screen (With F1 Record, F2 Display, F3 Display WO2)
    Display Data: Does nothing.
    Trace file sent to Paul on 3/22/08 @ 17:14 Central time
    May 2006
    Wink I Have the same symptoms on a LB7
    V2
    Controller: 01 LB7 (15063375)
    I Sent Paul An E-mail With Trace file so ill see what he turns up.
    2001 K2500HD Duramax/Allison
    Senior Member lakingslayer's Avatar
    Dec 2005
    I thought I was smoking too much crack and weed again but I guess not. Mine is doing the same thing. I need to look at the SD card to see if there is a trace file there. There is no indication that the Trace was stored like previous versions where it said something like "creating trace file".
    Jan 2006
    It doesn't automaticly generate the trace file. You'd need to manually generate it.
    Senior Member Wasted Income's Avatar
    Dec 2005
    Same problem with my LLY.
    Works fine on my 5.3L gasser though.
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    Its is a known problem with the LB7/LLY controllers. It has been fixed and an update will be available Tuesday (which is late Mon night in the US).
    Dec 2005
    Cool! Thanks Paul.
    Sep 2007
    As in last night?
    2008 Chevy DMax CCSB 4x4 LTZ LMM- EFI LIVE 500HP DD Tune, Suncoast 4 1057, 5" MBRP Turboback no cat/muff/*** , S&B Intake, SD Tie Rod Sleeves & Manifold, Cognito Pitman/Idler Arm Brace Kit, Transgo Jr., Belltech 3" Lowering Shackles, Escalade Handles, 5% tint all around, Billet Bowtie and Precision Billet Grille, V1. 10000K HIDs
    Dec 2005
    Quote Originally Posted by Code3Response
    As in last night?
    I would imagine they would like to fix the LMM issue with the next release. That's just a guess though.
    Quote Originally Posted by lakingslayer
    Correct.
    The LMM issue is now fixed and the update will be made available in a couple of hours.
