Results 1 to 3 of 3
Thread: $0185 error
    Lifetime Member hymey's Avatar
    Jan 2008
    Default $0185 error
    All good last night with the logging. Tried a log this morning. No good at all.
    Pressed F1 select vehicle...came up none loaded. Looked at the config files and there were none there! Tried to load the V8 config files back onto the the scan tool and the above error occurred. I can move across logs. But no config files?
    That is the third time that problem has happened. Twice on our test FlashScans and once on your FlashScan. The recovery is to reformat the Config file system and re-copy all the files onto FlashScan.
    If you can recall the exact sequence of events prior to the problem occuring, that may help us to track down the cause.
    Jan 2008
    Thanks Paul,
    I logged a quick session last night just to test it out. Didnt look at to many things in detail .I noticed the afrs were logging on the scantool.
    I went out this morning and turned the ignition on in the vehicle. Then connected the flashscan and attempted to connect to the vehicle through F1 and it didnt work.
    I cleaned up some of the excess efilive files today on my pc. I have 2 efilive hapi programs so i deletd the old one off as I was getting $0025 error when I tried to open efilive explorer.
    I deleted the old efihapi program and then I could open explorer. Must of been conflict somewhere. Its good now.
    I formatted the config section and the config files,option.ini come across no problems. I went for a drive today it was OK.
    One thing I must comment on is that the traction control light doesn't come on and off anymore like it did with the old firmware.
  1. Searched with no luck, $0183 & $0185
    By 05LLYMaxx in forum FlashScan V2 BB Logging
    Last Post: February 27th, 2010, 07:08 PM
  2. Error: $0185
    By gpr in forum Gen III V8 Specific
    Last Post: September 18th, 2009, 09:39 AM
  3. error $0183 and $0185
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: May 24th, 2009, 04:39 PM
  4. RAM Error
    By bobo in forum FlashScan V2 BB Logging
    Last Post: February 26th, 2008, 11:59 AM
  5. Error $0185 when copying files
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: December 31st, 2007, 06:19 AM
