Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: HELP!!!! VE seems wrong, after using RR
  1. #11
    Nov 2006
    from what i saw you are running lean pretty much all over.
    i also saw you are logging 2 WBO2`s and only
    one is sending a signal, but the one that is
    shows 1.49 BEN at its highest!
    it`s almost like you had the RR turned off and it was
    not updating at all, as the car warmed up
    it just got leaner and leaner.
    LOL i see now how you hit that range in the VE table, your cam.
    i must have a very small one because i idle in the 45 kPa range.
  2. #12
    Jan 2005
    Might want to double check that DFCO is disabled. DFCO got me the first time I used RTACS.
  3. #13
    Feb 2008
    Thanks for all the replies, I set up my normal tune to run rtacs instead of the auto ve tut file one... Turned of DFCO and set any cell in the afr comm table that was 14.63 to 14.5.. I then used rtacs to set up the TPS v VE table first and then went for a drive around.... much much beter... and the car is so different you would think some one did a motor transplant and took the cam out... it is so nice and smooth..
    Thanks to ntae, Jezzab for your msn and phone calls with advice..
    I will have to do the 80kph and up rtacs tonight and then get you guys attending the tuning convetion to check my work...
    I ate my bowl of Aussie rice for dessert, Main course was imported rice...
  4. #14
    Jan 2005
    glad it worked out for you
  1. what am i doing wrong?
    By BadLSX in forum Gen III V8 Specific
    Last Post: May 4th, 2010, 01:24 PM
  2. I think i did something wrong!!
    By 02Tahoe28 in forum Duramax LB7
    Last Post: October 2nd, 2008, 07:44 AM
  3. Can anyone see anything wrong here???
    Last Post: February 4th, 2008, 09:29 AM
  4. Something wrong with BBL
    By XLR8NSS in forum FlashScan V2 BB Logging
    Last Post: January 4th, 2008, 10:13 AM
  5. COS #5 what am i doing wrong!!!
    By AGRO in forum Custom Operating Systems
    Last Post: September 2nd, 2006, 12:13 PM
