Results 1 to 10 of 11
Thread: 4L80 no tcc lock up
    Sep 2009
    Default 4L80 no tcc lock up
    I have a 2000 carryover 3500 pickup. I built a mild 383 with a small camshaft, and ported stock heads. When I first put the engine in the truck, the tcc worked like it was supposed to, but I had a very lean condition due to the engine modifications. Before getting it tuned, I turned up the fuel pressure to help with the lean condition, and ever since, the pcm doesn't command tcc. Thinking it was just going to be a tune issue, and something to do with fuel trim, I had the truck tuned, and now it still doesn't command tcc. After an ignition cycle, it will lock up one time, but none more thereafter. The guy tuning disabled misfire codes, disabled fuel trim codes, and disabled o2 codes. It will lock up when commanded with a tech 2, but not on it's own. I don't know anything about tuning computers, and the guy doing the tuning has never ran into this sort of thing. Any ideas or suggetions?
    E.R.R, welcome to the forum...
    Log these pids: TSTATE00, 01, 03, 09, 10, 12.
    Also log: TCCMODE, TCCDC.
    the TSTATE pids should reveal the reason why the TCC is not being locked
    (on the PIDs tab, do rightclick->More Info on each one to see what the bits mean).
    He can't unplug the TCC because the TCC solenoid wire is included with all the other wires in a single connector...
    If he unplugs the connector, the trans will be stuck in one gear with max pressure (limp mode) and with no TCC function.
    D.Etefs welcome to the forum...
    What car do you have, and which model of EFILive do you have...?
    Sep 2009
    Ok, pids 09, 10, and 12 can't be looked at with my pcm. The more searching that I've done, the more I think that the problem lies in the misfire tables, which I can't view/change, either. Is there an updated, or any additional software that includes misfire tables for my pcm?
    Which PCM part number do you have...?
    Which OS are you running...?
    Not all PCMs/OSs have all the pids, but I don't know which ones... but we can ask someone here who will know.
    Sep 2009
    I believe it is the latest software. 16263494 is the pcm p/n
    If PCM detects misfires it will disable TCC lock up.
    I contacted Tech Support to find out what your OS/PCM abilities are.
    When you open the tunetool, goto View->Show Calibration Window and see what the OS it says (in the upper right box).
    Sep 2009
    I'll call the tuner tomorrow and get that info.
    Thanks for the help!
    OK, we'll be here, you're welcome.
  1. 4L80 wiring
    By ebayer5 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2009, 11:24 PM
  2. From a M6 to 4L80 speedometer problem
    By RandyWS6 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 6th, 2009, 11:12 AM
  3. 4L80-E stuck in 2nd
    By jpsxpress in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 3rd, 2008, 03:12 PM
  4. 91 K2500 4l80 gets stuck in 2nd
    By amh in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 30th, 2007, 09:40 AM
  5. 4L80 question
    By Dirk Diggler in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 12th, 2006, 12:17 AM
