Hi Guys,
I'm still having issues with BBL on the Holden E38 ( VZ ) controller. There are 2 main issues that I can see...
- DMA pids don't appear at all in the logs.
- Log data ends in the middle of a log session when viewed in the Scan tool..
The second issue is probably the bigger issue as I keep loosing data, well It's probably still there but I can't see it. I no longer get the errors on the dash like the previous version, which is a great start, but still get problems with the log file.
When reading the file in, Scan tool takes a lot longer to replot when opening the file. The files are also a fair bit larger than I expected, I'm not sure if this is just a new "feature" in BBL of if there is additional data getting stuck in there that makes them larger.
I can supply a couple of log files that have the hang in them if needed.
Simon.
