Results 1 to 7 of 7
Thread: Reading oil pressure and fuel temp on a LBZ
    Sep 2007
    Default Reading oil pressure and fuel temp on a LBZ
    I've tried to log those two items and it's a no go.
    The oil pressure reads like 3,000 PSI and up.
    And the fuel temp makes me other gauges (I think it's my speedo/rpm) gauge go whacky.
    Am I doing something wrong?
    I've tried to validate the PIDs also and it does the same thing
    Just confirm the readings are valid on the Data display Tab, not on the gauges, if they are ok in the data tab then you probably just need to set the dash gauges up.
    Sep 2007
    The readings I'm getting are from the data display tab and not the dashboard. Thats why I was confused.
    Jason,
    Did you enter the correct VIN/OS (File->Enter VIN) and PCM type (File->Select Controller) in the scantool...?
    Sep 2007
    Sorry Joe, just got this... No I hadn't tryed that honestly. I'll give it a shot! Thank you!!!
    No worries, take your time.
    May 2007
    Any luck with this Jason??
    '07 LBZ Classic, BW S464 Turbo, EGR deleted, 3" IC piping, Trans-go, ATS 5-star converter, stock clutches
  1. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  2. vx ss fuel pressure????
    By HINDZY in forum Gen III V8 Specific
    Last Post: October 12th, 2007, 02:27 PM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. Fuel Pressure.
    By 06bowtie_guy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 24th, 2007, 06:37 AM
