Page 1 of 11 123 ... LastLast
Results 1 to 10 of 104
Thread: BB Logging beta update: March 26, 2008
    Default BB Logging beta update: March 26, 2008
    Download here:
    http://download2.efilive.com/Softwar...ch_26_2008.zip (18Mb)
    This download includes and supercedes the previous (March 20) download.
    Make sure you update your FlashScan (and/or AutoCal) firmware using the latest firmware file(s) in the EFILive_Hapi folder.
    Please read the first post in the March 20 release for further information.
    http://forum.efilive.com/showthread.php?t=7566
    If you have previously updated to the March 20 release and performed the steps in points 2 and 3, then you do not need to perform those steps again.
    Jul 2007
    Thanks Paul,
    Just a quick check on the options.ini file..... Todays update seems to have an incomplete options.ini file in it, as there is no PID selection section for E38's. Can I just copy the section from the previous update?
    Simon.
    Jul 2007
    Sorry, just realised it's using the LS2 section
    Jul 2003
    Does it fix the AFR pass thru?
    Paul,
    I have been hesitant to download this update as our tuning workload is jambed. Can't afford to have a non functioning V2. Should we hold off or is it a fairly stable update.
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Jul 2007
    I just tried a quick E38 BBL session and I still cannot log any DMA PID's. the options file has the following defined....
    ECM, ECT, -40:110:1:1:0
    ECM, IAT
    ECM, MAP
    ECM, E38.APCYL_DMA
    ECM, RPM, 0:6500:2:1:0
    ECM, SPARKADV
    ECM, ETCTP
    ECM, VSS
    ECM, E38.AFRATIO_DMA
    ECM, KR, -1:1:34:5:0
    ECM, E38.OCTSCL_DMA
    But none of the "DMA" pids appear in the log file. I'll try a long-ish log tonight to see if the lock up problem is fixed.
    On my previous post about the options.ini file.... Is is safe to assume that under the "Vehicle Selection List", the "PSL" column is simply a text pointer to a config section further down in the file? Can I recreate the E38 section for myself ( understanding that the options file is overwritten with an update ) without effecting anything else?
    Simon
    Sep 2003
    The 98 Controllors still don't work. If I select 98 Manual and go to 'Display Data', it says 'FUELSYS is not a valid PID. If I remove that from the 'Options.ini' file, it says that 'MAF' is not a valid PID.
    I returned everything to original and select 99 Manual and then 'Display Data' and it likes it. There must be something wrong in the LS1A_M.pmm and LS1A_A.pmm files because the 98 & 99 are using the same PSL_LS1 section in the 'Options.ini' file. I also tried 98 Auto and that fails like 98 Manual.
    DMA PIDS also do not work.
    Quote Originally Posted by swingtan
    Simon
    Yes, its just a reference to a named section further down in the file, you can make up others as you want/need to.
    Quote Originally Posted by Highlander
    Yes.
    Quote Originally Posted by Ninety8C5
    Strange, I just tested it again here and it works fine. Did you upgrade the firmware to release: (0326)? Did you copy the new *.pmm files to FlashScan?
  1. BB Logging beta update: May 19, 2008
    Last Post: June 11th, 2008, 10:22 AM
  2. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  3. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  4. BB Logging beta update: May 03, 2008
    Last Post: May 5th, 2008, 02:43 PM
  5. BB Logging beta update: March 20,2008
    Last Post: March 23rd, 2008, 09:13 AM
