OK im gonna put a 2 stage 350 hp dry nitrous kit on the car..
stage 1- 3200-7000 rpm 175hp
stage 2- 5200-7000 rpm 175 hp
Right now im at 12.5 afr at WOT... and i want to be at 11.5 afr at WOT when the nitrous is on.
so according to the math I need to add 10% to the VE the correction factor, set it 1.099 from 3200-5200 rpm's and from 5200-7000 rpm's I need to add another 10% for a total of 20% more to the VE multiplier table making it 1.199..
should I round up to the nearest # or leave the correction factor as it comes out??
is this correct??
add more VE 20% total when the 2nd stage kicks in cause im spraying both shots at the same time..
any thoughts??
