Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: downloading stock tune help!!!
  1. #31
    Wait until we post up the May 19 update - should be available within 24 hours - probably sooner.
    It will be posted in a new thread in the forum I linked to previously.
    It will contain a zip file that you need to download to your laptop.
    You must have the latest V7.5.3 software installed (or already be using the V7.5.4 beta software).
    Then just unzip the downloaded zip file into the folder: \Program Files\EFILive, overwriting all existing files of the same name.
    Then locate the file \Program Files\EFILive\Readme_First.pdf. Read that file carefully, it explains how to upgrade your FlashScan's boot block and firmware and how to start using the new software.
  2. #32
    Mar 2008
    i downloaded everything and installed everything and i get the same bootloader error
  3. #33
    Mar 2008
    scratch that, tried it again with alt keys and it worked. THANKS GUYS!!!!!!!!!!!
  4. #34
    Mar 2008
    Do you guys want me to send you any files? If they will maybe help with your adjustments. Everything works for me but there are still unlocking things on the screen.
  5. #35
    weettiddo007,
    Can you capture screenshots and post them in this thread...
    How to post images
    Thanks,
    Joe
  6. #36
    Mar 2008
    will do, im going out later tonight and ill take some shots then.
  1. Possible stand-alone tune downloading
    By Brian1 in forum FlashScan V2 BB Logging
    Last Post: May 7th, 2009, 09:06 PM
  2. downloading stock tune ?
    By CountryBoy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 26th, 2008, 04:09 PM
  3. Need Help! Problems downloading stock tune
    By dodson914 in forum E37, E38 & E67 PFI ECM's
    Last Post: April 6th, 2008, 06:56 AM
  4. downloading stock tune
    By sweetdiesel in forum General (Diesel)
    Last Post: April 9th, 2006, 04:33 PM
  5. Problem Downloading a Stock Tune
    By JrTuner in forum Duramax LB7
    Last Post: January 7th, 2006, 05:32 PM
