Results 1 to 4 of 4
Thread: E40 ECM locked
    Jul 2007
    Default E40 ECM locked
    This morning I tried programming a 2006 Trailblazer SS. The flash looked like everything was ok. Went to fire the truck and nothing. I tried to do it again and it said it was locked. I had a local tuner do some tuning with HP tuners for an sts turbo I put on but if he locked it, would I even be able to read it to begin with? I am kind of new to this at least with LS2's.
    On the E40 I've been told by a couple of tuners that every now and then after a flash you need to pull power to the ECM for 10 seconds or so.
    It's normally a rare occurance, so I am surprised you got it on the first time you flashed the car!
    Give that a go.
    Jul 2007
    Great! Thanks for the info. I am out of town but will try when I get back and give an update.
    Jul 2007
    That solved the problem! Thanks Ross!
  1. I Locked PCM but now have new V2
    Last Post: September 16th, 2008, 01:13 PM
  2. locked ECM
    By duramaxdaddy29 in forum Duramax LB7
    Last Post: June 4th, 2008, 05:30 PM
  3. Locked E40
    By Jakes4321 in forum Gen IV V8 Specific
    Last Post: March 22nd, 2008, 08:04 PM
  4. Locked PCM?
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: March 16th, 2006, 01:46 PM
  5. 98's (Locked)
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2005, 09:54 AM
