Tom is going to help me hook up a Road Runner to the 2000 to 2003 PCM soooooon
Well, I can tell you for sure, you don't wanna know WHERE it is.... We won't go into what it is....
IIRC the module gets crank/cam sensor inputs but still waits for EST signal from the PCM telling it the delay (+ or -) on when to actually trigger the flyback.
So the sensor inputs might need to be tweaked if the N* and LS1 use different crank triggers. should be quite easy really.
Yes Tom.
I wanted to meet up with you today at the track and give you one of my spare PCM's to this this going. I am only going to be up here for so long and then I need to be with my Family. I only have one test car and it is up here.
Well maybe I will have to drive down by you.
Also I think I have another way to read the old Delco PCM the Caddy used from 96 to 99.
I have been thinking about this way too hard.
This PCM.
I think Loyde told me a trick a few years back.
I am sure you know how to do that Ross
