Anyone help me out with injector table setup for 60 lb motoron injectors on a VZ 6ltr ute.
IFR table runs out of range for my calculated injector slope
Whats the flow rate of the inj @ 43.5 psi?
Are you running 58psi fuel pressure?
Do you have a manifold vacuum referenced fuel reg and is the vac hose hooked up?
Ive got 63lb Semiens Dekkas on a VU SS Ute and they dont run off the scale.
Jez
I have them in my VXII as well, no problem.
But the 6 ltr cal has a max setting of 7.9999 gms/sec
and the ls1 cal has an upper limit of 511.9922 gms/sec
Base fuel pressure = 58 psi, not boost referenced.
60 lb @ 43.5 psi
Going by my ls1 setup the IFRs start at 8.7266 through to 9.5625 gms/sec
ok spotted wait4me s post on injector size fix, may have to give this a go.
Anyone know the std injector size for the VZ 6.0 ltr L76 ?
