01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
The only reason that I can think of is to run the pump at a cooler temperature and not kick it up with the BAP until you need the pressure?
I run at 52 PSI and when the Aeromotive pump controller sees 0 vac/0 boost it activates to the higher voltage and the PSI slaps to 58 and then rises 1 PSI of fuel pressure for every 1 PSI of boost. I end up at 72.5 PSI of fuel pressure at full boost.
I can't really see a reason to run at lower fuel pressure unless you are strapped for the pump being able to handle the full load or you are running small fuel lines?
Elmer
Some people run the lower pressure so they can better control their big injectors at idle...
the larger injectors are more prone to physical (mass/inertia) effects... they have a "minimum" on time.
We did a 440TT c5 a few days ago with the 79# racetronix's injectors, just a base tune for idle so he could run it for a 30 minute break in period, it settled right into idle at 800RPM with a few tweaks of desired airflow and VE once we input the correct IFR table and accounted for the extra cylinder volume, it was really easier then i had expected it to be, although the RR plays a huge part in that.
I see the logic in your statement Joecar, im just assuming from my experience that this is not neccesary with the racetronix 79's
WWW.EFIAlchemy.com
Oh, the Racetronix 79'ers must be well behaved (high quality)... cool...
AJ/WHYTRYZ06, you should able able to calculate your IFR table using your measured rail pressure and you should be good to go.
