Results 1 to 5 of 5
Thread: injector pulse width max?
    Oct 2007
    Default injector pulse width max?
    hi all, can anybody tell me what my injector pulse widths should stay under? at the end of the drag strip i am at 99% injector duty cycle ( time to ungrade i know) and 17.945ms pulse width. pulse width reaches 17ms at around 87% duty cycle. what would normal pulse width be? thanking all pete
    Jul 2005
    it depends solely on RPM. at what RPM did you get the 17ms IPW?
    You should be looking at duty cycle, which is maximum at 100% (and above that is the same as 100%).
    It is recommended to run no higher than about 80% for various reasons.
    17ms at 87%dc comes out to a period of 19.45ms which is 6141rpm...
    your PW is 17ms, the maximum PW is 19.45ms at 6141rpm.
    (6000rpm is a period of 20ms).
    Jul 2007
    As stated, maximum injector pulse width is dependent on the RPM of the motor. The basic formula is...
    1 / RPM / 60 = "cycle time" in seconds
    However, the LSX motor fires the injector twice per cycle, so the formula changes to...
    1 / RPM / 60 * 2 = "max injector pulse time" in seconds
    To convert the result to mS ( milliseconds ) just multiply by 1000. This will give the maximum amount of time that the injector can be open for before it overlaps the into the next cycle of the motor.
    The accepted maximum duty cycle is 90% of the maximum so you need to multiply the the result above by 0.9 to get the maximum time the injector pulse width "should" reach. Here's a quick graph showing the maximum times from 4900 RPM to 7000 RPM.
  1. (B3701) Injector Pulse Width values for SVO 42# Injectors
    By DrkPhx in forum General (Petrol, Gas, Ethanol)
    Last Post: September 13th, 2009, 02:56 AM
  2. injector pulse width for motron 60lbs
    By BROKE in forum Gen III V8 Specific
    Last Post: September 30th, 2008, 04:24 AM
  3. Small Pulse Adjust/Low Pulse Width Injector Offset
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: September 4th, 2007, 09:05 AM
  4. Injector pulse width
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2006, 01:49 PM
  5. Minimum Injector Pulse Width
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2006, 11:28 AM
