What size wire did you guys use? Can make the wires a least 2' long or is there a distend requirement?
2006 Trailblazer SS
Twin Turbo 67 Chevy Truck
SOLD Truck 2002 Chevy kb turbo t70 5.7l
whats the leatest on this guys?
i just bought a PLX and would like to do this so i can start tuning my new cam/turbo/meth setup..
This thread is the latest.
I did the mod today and it was a breeze. Relocated the two components to make room and mounted the db9/max232 adapter to the back panel. used the cable that shipped with V2, cut the DB9 end off and replaced it with a male gender Db9. wired it so there's no need for a null modem (connected red to 2, black to 3 and white to 5) then configured v2 so it sees the WBO2 on the RJ12 jack. it worked the first try and couldn't have been easier! well, until they ship a TTL converter in the PLX. lol
2001 Camaro SS
EFILive Custom OS3
Hey Guys, thought i would post up a pic of the guts of the M300 Tuner edition.
It's basically a normal PLX with an extra card for the display and fuel selection switch, funnily enough it only uses Power,Ground & the TX feed the same as the rs232 to ttl.
So use the pictures to enable serial output with your rs232 to ttl converters.
Can somebody give a parts list of whats needed and where to get it. Ive never done anything like this so im kinda leary of ordering something that i dont know about..
Thanks guys..
Jonathan
Well i ordered the rs232 board from here. http://www.nkcelectronics.com/rs232-...33v232335.html
then use a gender bender and cut my efilive cable to modify the pins. But if you used a null-modem adapter you wouldnt need to cut the cable.
then i use the old Analog cable that used to plug into computer cd-rom drives (it's a 4 pin adapter) and then use that on to my board.
Can someone give me a part list of what I need to do this and what the parts look like so I order the correct parts. Thanks Thomas
2004 silverado rcsb 2wd 5.3, 3.42's, 4l80e w/hd-2 and yank 3200, 01 LS6 cam, walbro 255hp intank pump, edge products 60lbs injectors, sts rear mount, EFILIVE with help of Nelsonperformance.
save your time and money and go buy another wideband.
If got issues with all 4 of my plx's being out for afr.
I'm not an EFILive user (I use HPT and DHP Powrtuner for GM 3800s) but I found this thread useful so I thought I'd share. I have 2 PLX SM-AFR units modded the same way and they work great. I recently (9/9/10) purchased a M-300TE and it has a new version of the display board v1.1. Makes hookup even easier.
Pre-mod
Post-mod
