Page 12 of 12 FirstFirst ... 2101112
Results 111 to 117 of 117
Thread: PLX SM-AFR Serial upgrade
  1. #111
    Quote Originally Posted by rich24v View Post
    Please can somebody point me towards the guide for setting up the analog 5v pids for plx wb's, specifically how to program the V2 aswell ?
    Thankyou.
    Connect 1st PLX to AD1+ signal and AD1- ground.
    Connect 2nd PLX to AD2+ signal and AD2- ground.
    Log the pids EXT.AD1 and EXT.AD2.
    Select the calc pids CALC.AFR_PLX1/2 and CALC.BEN_PLX1/2.
    In FVS2 device settings, checkmark the box to always include External Analog Pids.
  2. #112
    Junior Member rich24v's Avatar
    Jun 2011
    Thanks Joe, think it worked out ok, although more fumbling than knowing what I'm doing
    I had to remove some odd pids that it did'nt like, maybe that's because I still have the HPtuners 2bar custom tune loaded,
    but at least I am slightly further forward. I can't see the BEN pids...are they to convert the voltage to the AFR ?
    I have boost via plx and fuel pressure via aeroforce 150psi sensor to set up next.
    UK spec 2009 HSV VXR8 6.2 LS3, E38, HeartBeat Supercharger running ~9psi,1 7/8" long tubes, cat back exhaust.
    Upgraded cam and springs of unknown specification, all I know is, it's a small cam with no overlap, suits the s/c.
    ATI damper, LS9 twin plate clutch, 548rwhp. twin PLX widebands to twin gauges.
    Currently running dismal HPTuners....NOW DUMPED !, Completed migration to EFIlive and slowly mapping it in.
    628rwhp.....with a lot of tuner help
  3. #113
    On the PIDs tab, look at the right-hand column, it is titled "Parameter", click on the title (the word "Parameter") to sort alphabetically on that column...
    then look down that column until you see the pids CALC.BEN_PLX1 and CALC.BEN_PLX2...
    the BEN pids are the correction multiplier, to see their definition do rightclick->More Info on each of them (on the PIDs tab).
    Summary: the AFR pids convert voltage to AFR; the BEN pids calculate the correction multiplier (to apply to your VE or MAF tables).
  4. #114
    Jun 2011
    Do I have to add these pids to the list ? if so I get error :-
    If I add anyway, it lists it with the red cross through it:-
    A bit lost..........
  5. #115
    I don't remember from your other thread... do you have an LS1B or an E38...?
    Whenever you see a red X thru a pid on the PIDs tab, on that pid do rightclick->More Info to see why.
  6. #116
    Jun 2011
    I'll switch to my original thread https://forum.efilive.com/showthread...L-Heartbeat-sc I don't want to clutter this one further.
  7. #117
    May 2017
    Hello . Doez anybody can help me with dump of the pic microcontroller inside or some schematics for plx v3 ? Thank you verry much . Also closer picture with all components it will be helpful thank you .
  1. BBL & Serial LC-1
    By L31Sleeper in forum FlashScan V2 BB Logging
    Last Post: January 19th, 2010, 12:01 PM
  2. plx sm-afr serial
    By blazinblue in forum General
    Last Post: June 23rd, 2009, 08:29 AM
  3. Replies: 50
    Last Post: March 15th, 2009, 04:00 PM
  4. Where are we with serial WB???
    By Redline Motorsports in forum FlashScan V2
    Last Post: August 13th, 2008, 09:26 AM
  5. WB serial to LT serial?
    Last Post: May 12th, 2008, 10:17 AM
