The table is cool and all BUT, every time I use it it skews w/my WOT AFR's.. Either it makes it richer or leaner, what to do?? How can we get around that???
Do I log it and drive in WOT and and hope it adjusts my WOT to my PE table depending on IAT temps???
I noticed my logs and at IAT's 50*f fuel is off by 1.06 ben and at 68*f off by 1.02 ben this is off my A0014 map in my logs.. This is all in WOT, I used a filter to eliminate all data under 90% throttle. If I dont use the filter @ 50*f its at 1.02 ben and 68*f its at 1.03 ben
So if I use the WOT #'s 1.06 and 1.02 what will happen to the VE table under normal driving, also Im running in semi-open loop.. so im NOT in full OLSD...
Can someone explain to me how the table works when your in WOT.. I use my PE table for WOT fueling...
Or maby use B3647 to control fuel and use A0008 to help w/ getting my fuel the way I want it.
thanks...
