[quote=redhardsupra;67478]i'm not sure what is there to be confused about:
That was a little joke. I guess it was a too subtle.
2003 red vert
Mods:
LPE 100mm MAF
RPM Level 6/4L60e trans
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
www.redline-motorsports.net
1-954-703-5560
2006 ZO6 895/866 with APS TT
2011 HTR-850R Camaro
if they're measuring fuel pressure, wouldnt there be a part number for some sort of sensor? do we have any gm dealers onboard to check it out? the big question is do they measure it, or just regulate it and hope it behaves as intended?
Well its in the 07-08 ZO6 files and my whole point was if we are modifying this table, it only really needs to be adjusted from the halfway point as half the table is out the range of the NA ZO6....
1-954-703-5560
Howard,
It would seem so. You know I calculated the IFR for the stock LS7 injectors for my 2003 vette. I doubt if it's a coincidence that the calculated values fit neatly into the 400 to 480 range. The only areas where the numbers change.
Joe
2003 red vert
Mods:
LPE 100mm MAF
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
So Joe, based upon that, we are only using 6-7 locations of the IFR table when making an injector change. What is all the other resolution for?
Even it is used for a supercharger.
1-954-703-5560
I'd have to assume that the Gen-IV cars are the same as the trucks... which have a Fuel pressure sensor from the factory. Check the PID SAE.FRP. That table allows the PCM to maintain stable fueling in a wide variety of conditions, including undesirable ones such as a faulty fuel pump or regulator. Very cool stuff.
1-954-703-5560
