www.redline-motorsports.net
1-954-703-5560
2006 ZO6 895/866 with APS TT
2011 HTR-850R Camaro
No clue Howard and the values in B1210 follow the same pattern.
B1206 might be a reason for limiting IFB values, but I don't see anything that explains the outlying values.
While looking I noticed B4001 and B1210 are labeled MAP, but "injector parameters" offers a choice of MAP or VAC. My file has VAC selected.
2003 red vert
Mods:
LPE 100mm MAF
RPM Level 6/4L60e trans
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
so from what I get delta map psi is fuel pressure vs what injectors flow over fuel pressure change
I have a 2010 6.0 suburban motor 6.0 with l92 heads we make them 408strokes they have changed injectors 3 times from 07 to 2010 the 2010s from what i get here have around 55 lbs injectors.
I engine dyno test them befor they leave with a e38 sd tune I made to make sure every things ok I put the first 2010 on and its like 10 to 1 afr I get looking at b4001 it has 55 lbs injectors going off what it seems here I been trying to figure out how that table works for some time (posted while back )seems funny tune says its not flex fuel with that size injectors its over kill for stock great for me.Hear is stock tune
deltaMAP = pressure difference across injector = absolute rail pressure - MAP
note: absolute rail pressure = 500kPa absolute = 400kPa gauge (58psi gauge)
e.g.
deltaMAP=400kPa --> at WOT with NA
deltaMAP=440kPa --> cruise with OEM cam (40kPa vacuum)
deltaMAP=460kPa --> idle with OEM cam (60kPa vacuum)
deltaMAP=500kPa --> theoretical full vacuum (100kPa vacuum)
deltaMAP<400kPa --> boost (MAP > 100kPa)
Almost, not quite...
Stock FPR is set constant to 58 psi (i.e. unreferenced returnless system), fuel pressure should not change... but pressure difference across injector changes as MAP changes...
flowrate is proportional to squareroot of pressure difference across injector,
so ECM has to account for changes in pressure difference across injector due to changes in MAP.
e.g.
What happens to pressure difference across injector when MAP is:
40kPa...?
80kPa...?
100kPa (WOT)...?
(absolute rail pressure is 500kPa)
If you have a manifold-referenced FPR (i.e. with return line), then, the FPR will vary rail pressure (as MAP varies) to always keep pressure difference across injector constant...
in this case, the injector flow rate will be the same value regardless of MAP, and table B4001 will be flat static (same value all cells).
ok I see what you are saying maybe lol It takes Into the fact that say 60 kpa its sucking on the injectors harder so they flow more. so if it uses 400 delta map psi as a rail pressure (58lbs )looks like the number to figure injector size thats in the motor.
I understand as vac.goes up the injectors will flow more.Its like a map pressure differance vs injector flow (how it changes injector flow)
but little confusing 400 kpa is 58 lbs. the fuel pressure is 58 lbs but it doesnt change its almost like its a fuel rail pressure table for the injectors
So if I get it 400 kpa is wot injector flow for say 100 kps map and say 460 kps would be high vac. so injectors will flow more say around 4lbs on this tune.
If it had boost then delta map would go down and injectors will flow less say under 400kpa like 350 kpa because you have boost pushing on injectors
ok hope my slopy typing hasnt killed you lol better with wrenchs thanks
