The problems that have delayed this next update have been resolved.
The next release had been packaged and is being tested internally here at EFILive. If all goes well with that test it will be available in the next 24 hours, or sooner if we are satisfied with the testing.
I've attached the "new features and bug fixes" document so you know what to expect when it is released.
Please note, this next update will require a boot block update. The firmware will also have a version number increase and that means once it is programmed into the FlashScan device you will not be able to "down-grade" to a a previous boot block or firmware version.
