Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Stock .tun/.ctd for '09 G8
    Nov 2006
    Default Stock .tun/.ctd for '09 G8
    I need a stock file for a 2009 Pontiac G8 GT 6.0L
    The pcm is locked and I'm going to buy a new one.
    LC-1 WBO2
    Nov 2006
    LC-1 WBO2
    Auto or Manual?
    Either way, swapping around E38's is a pain, make sure you get one from the right year, get the Service Number off the ECM and make sure it's a match.
    Nov 2006
    I can't just upload to any E38!?
    E38 serv# 12612384
    I tracked down the previous owner and have come to terms with the said locking device.
    Stay tuned.
    LC-1 WBO2
    I'm not sure if the E38 compatibility question was going for a laugh?
    Have you considered sending it out to get unlocked? You could count on it being the correct ECM.
    Al
    Nov 2006
    The vehicle needs to stay running.
    I will still need a stock file to compare to whatever PCM I use.
    LC-1 WBO2
    Still whatever ECM you buy unless its from an 09 G8 GT will need to be flashed with a Tech II before you can do anything with EFILive...
    Mike, what have you gotten yourself into...
    Nov 2006
    WoW.
    Let this be a lesson for all of us.
    If you are going to buy a used car, make sure the PCM isn't locked first.
    LC-1 WBO2
  1. Need help finding stock .tun file 99 Vortec 7.4
    By dave w in forum Vortec V6/V8 Specific
    Last Post: November 30th, 2010, 03:53 AM
  2. 2009 LH8 5.3 only 300hp, take a look at the stock tun
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2009, 02:02 PM
  3. EFILive Stock *.tun Files!!! In Here!!!
    By Black02SS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2008, 07:45 AM
  4. Getting a stock 2002 C5 A4 .tun file
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: June 25th, 2005, 01:33 PM
