Can I use EFI live to turn an electric fan on and off?
Im in a Hurry and have no time to search sorry to ask if its allready there
1972 Chevy Blazer, Twin Turbo Duramax 6.6
69 Maro TT 427 LSX, Wayne due Vett frnt sub,
Lateral Dynamics 3 link rear, D 60,
T56, 18X10' 18X12 Boze Forged Speedsters,
13" wilwood 6 pot fronts 13" wilwood 4 pot rears,
(all Still under construction)
Yes, with some limitations....
2005 RCSB 2500HD GMC Sierra DURAMAX LLY
1955 Chevy Truck 1st series, being restored
2002 Mercedes C270 CDI
As Lennart said, with limitations, it would be crude but might do the job. Complete fan control is more complex that the calibrations available for the output control.
Also, if you do hook it up, make sure you are switching the fan relay, not the fan directly or you will be up for a new ECM!.
Assuming that you are removing the stock cooling fan (don't mean to be nosy )...don't plan on using the LLY to pull any significant loads if you go electric. FWIW
Custom Tuning Services
I am thinking about running the 05+ GM Gasser fans. Never tow with my truck just race the streets with it. No Phoenix weather over here either!
