Page 1 of 7 123 ... LastLast
Results 1 to 10 of 73
Thread: BB Logging beta update: April 07, 2008
    Default BB Logging beta update: April 07, 2008
    This BBL update has been removed due to a potential failure of FlashScan units.
    DO NOT UPGRADE YOUR FLASHSCAN UNIT TO BOOT BLOCK VERSION V2.05.06
    PLEASE NOTE!!!!!!!!!!! When you download this zip and go to install the firmware, YOU MUST INSTALL THE BOOT BLOCK UPDATE V2.05.06(0407) FIRST on your V2! Failure to do so will make your V2 unit not talk to EFILive Hapi and will not work.. Then after you install the boot block update you can continue to install the Firmware. But only after the boot block update.
    ALSO Do not do full flashing of a new custom os for the pcms/ecms. There is a known bug that wont allow the computer to be seen while the cal segment is empty. Fix will be soon.
    Download here: Download is no longer available
    This download includes and supercedes the previous (March 26) download.
    Please read the Readme_First.pdf file included in the zip file.
    It contains important, updated information about how to upgrade the boot block in your FlashScan and/or AutoCal devices.
    Make sure you update your FlashScan (and/or AutoCal) firmware and boot block using the latest firmware file(s) in the EFILive_Hapi folder.
    Please read the first posts in the March 20 and March 26 releases so that you are aware of the previous versions' pre-requisites.
    http://forum.efilive.com/showthread.php?t=7643
    http://forum.efilive.com/showthread.php?t=7566
    Oct 2006
    Alright , found it this time .
    2006 Trailblazer
    Sep 2003
    i think there is a typo in the Readme_First.pdf file. On page 8, Step 6 item 3 it says to "Check that the Boot-block Version is 2.05.04". If we just updated the Boot block in step 5, item 4 to V2.5.06, shouldn't that be what we see?
    I just want to be sure, I don't make a mistake.
    Oct 2006
    I've got a window that is asking me for a password to continue .
    "File EFILive _Tune.exe" is password protected .Please enter the password in the box below .
    I un-zipped the file to \Program Files\EFILive\ (overwrite existing files) , clicked "yes to all" , process started and got almost finished and again was asked if I wanted to overwrite a file , EFILive_Tune.exe I answered "yes to all" again , and was presented with a Password needed box .
    Do I skip file or what ?
    2006 Trailblazer
    Yes you are right, it should say "Check that the Boot-block Version is 2.05.06".
    Thanks for finding it, I'll get the doco updated.
    Quote Originally Posted by Ninety8C5 View Post
    Jan 2005
    GM - I had that happen to me once upon a time ago. Turned out to be a corrupted zip file and I had to re-download the file.
    Oct 2006
    Thanks TAQ ,
    Just DLed again , get the same Password needed box , at the same point in the process .
    Here is what gives me the Password needed "File V7.5\EFILive_Tune.exe is either a read only , system , or hidden file. Would you like to replace the existing file."
    If I skip , I get another Password needed for "obdiiV7.dll" .
    2006 Trailblazer
    Sep 2003
    I don't know if this is your problem or not, but right click on your zip file and go to 'Properties'. You might see a button label "Unblock". If you do click the button and then the "Apply" button.
    After that you should be able to unzip the file without the warning messages. I think that started on my PC and laptop after an update to XP.
    Mine worked fine after doing the above.
    Oct 2006
    Just DLed with the tuning laptop (used just for tuning) to it and it worked this time , maybe something was getting lost between transferring the data from one laptop to a SD card then to a different laptop .
    2006 Trailblazer
    Aug 2005
    Hey Paul,
    Still seeing the bug I emailed you about on the T42 controller. All base pressure tables are showing max values. Opening the tune file up in 7.5.3 shows the correct values.
    Justin
  1. BB Logging beta update: April 26, 2008
    Last Post: July 19th, 2008, 04:44 PM
  2. BB Logging beta update: May 19, 2008
    Last Post: June 11th, 2008, 10:22 AM
  3. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  4. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  5. BB Logging beta update: April 14, 2008
    Last Post: April 23rd, 2008, 08:46 PM
