Results 1 to 6 of 6
Thread: Allison clutch question
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Default Allison clutch question
    Dumb qustion: Would it be possible to use EFILive's DVT to apply the C2 and C4 clutches manually for the 6th gear (Assuming the truck had a 6 speed VB, of course) with a 2001-2005 TCM, or would the TCM scream about an invalid clutch pair? Which solenoids are used to apply which clutchpacks? My Assumption would be SSA -> C1, SSB -> C2, etc, but I could be wrong.
    Senior Member lakingslayer's Avatar
    Dec 2005
    I'd say if you can do it with at Tech II then you should be able to with the DVT. I don't think the DVT is going to give any more abilities than the Tech II gives.
    Jan 2006
    Well, that's the thing; I don't know if you can o it with the Tech2. In DVT, it allows you to manually apply solennoids, so as long as the TCM doesn't scream about an invalid solenoid pair, it should work in theory.
    Mar 2008
    Wish I could apply the two clutches with a manual switch on the dash. Kind of like a manual OD switch.
    Tony
    Mine2001 GMC 2500HD EC/LB, D/A. 4in MBRP exhaust, AFE Stage II w/Amsoil Ea air filter, ISSPRO boost/Pyro guages, PPE Boost Valve, EFI Live V2, Maximum OD Stage 2 Trans, Amsoil throughout, AirDog150, modded intake horn.
    540HP/1056TQ
    Dyno'd Danville Performance
    April 5th 2011
    Hers: 2006 GMC Envoy XL Denali, Flowmaster 40 with a bullet style resonator in the back, EFI Live with the help of JoeCar and other great members here.
    Jan 2006
    Quote Originally Posted by horsehaulin View Post
    Tony
    Won't work unless you have a 6 speed valve body... If you have a 5 speed VB, not a 6 speed, it'll drop into neutral if you try to apply the 6th gear clutch combo. (Assuming the 5 speed TCM will allow the combo).
    Mar 2008
    I am getting the 6spd conversion next year since I spent such a big bill on the rebuild I want to wait for the next sticker shock! Given that I dont have to spend all I make for saving for the conversion in fuel!
    Tony
    540HP/1056TQ
    April 5th 2011
  1. Clutch Relearn?
    By Chalky in forum Gen IV V8 Specific
    Last Post: March 16th, 2009, 01:08 PM
  2. Question about Allison 6 Speed shifting strange
    By LBZoom in forum Allison 5 & 6 Speed
    Last Post: July 5th, 2008, 08:04 AM
  3. LBZ Allison simple question
    By Boost in forum Allison 5 & 6 Speed
    Last Post: May 30th, 2008, 12:31 PM
  4. Best way to monitor clutch slip
    By robz in forum General
    Last Post: March 12th, 2008, 11:30 AM
  5. Car dies when i hit the clutch...Little help plz
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2006, 11:32 AM
