Results 1 to 4 of 4
Thread: to turn off AIR pump
    Mar 2008
    Default to turn off AIR pump
    I put headers and offroad xpipe on my car...so no cats...tubes are connected to the headers but no need for the AIR pump to run....what do i need to put the settings for the AIR pump to, to disable it....anything else you guys can think of for my newest mod...havent installed my LC1 wideband yet Im going to install that before i do any logging....turned off the rear 02s and messed with my fan settings and turned off the cat protection
    Ok thought my tune was stock but downloaded a stock tune...they added some timing...so i checked out the low octane timing table....is that if your knock sensors detect knock it goes to the low octane table? anyways the High Octane and Low Octane tables are exactly the same
    Jul 2007
    Change B0201 to zero. Then disable the codes to prevent the MIL.
    Also, physically remove the AIR pump or it will collect condensation and will pop the next time you run it.
    Member TJWells's Avatar
    Apr 2008
    I changed B0203 to 140. since I don't often drive through Hades It never comes on and no worries of a check engine light. 2000 vette.
    By the way, shutting off the air pump made a huge difference in the way the car drives at low rpm. I really love the change.
  1. LTFT - leave on or turn off?
    By billiardcue in forum General (Petrol, Gas, Ethanol)
    Last Post: October 19th, 2008, 06:44 AM
  2. Car dies when I turn on the A/C
    By Powerhouse in forum Gen III V8 Specific
    Last Post: July 29th, 2007, 01:05 PM
  3. Why do a lot of Pro Tuners turn the P1336 enabler off?
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2007, 12:59 PM
  4. How do I turn on the charts?
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 6th, 2006, 12:32 PM
  5. Idles fine till I turn on AC
    By skippy in forum General (Petrol, Gas, Ethanol)
    Last Post: June 8th, 2006, 04:02 AM
