Results 1 to 10 of 12
Thread: LB7 ECM Read issues
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Default LB7 ECM Read issues
    I picked up an LB7 ECM and attempted to read it. First time it took a try or two, and when it finally went to read the ECM, I got:
    "EFILive has detected that this ECM may not have a valid calibration."
    It then read it and appeared to bring up a good calibration.
    Now it started giving me:
    18:11:08.572: ECM not secured
    18:11:08.576: Initializing ECM...
    18:11:09.303: Initializing ECM, step 1 of 4
    18:11:09.306: Initializing ECM, step 2 of 4
    18:11:10.040: Initializing ECM, step 3 of 4
    18:11:11.465: Initializing ECM, step 4 of 4
    18:11:11.731: ECM lock has been re-armed, attempting to unlock ECM again...
    18:11:11.884: Initializing bootloader...
    18:11:11.951: Error: Failed. Controller has returned to normal operation, please retry the operation.
    18:11:12.158: Initializing bootloader, step 1 of 3
    18:11:12.160: Error
    18:11:12.162: Disconnecting ...
    As near as I can tell from this post by Ross, the ECM's S/N, seed/key and VIN are wiped (although when I get the calibration info from the tune tool, it displays VIN, OS and segment info, but no S/N, CALID, hardware # or BCC). Any chance of some kind of CPR since it still displays the VIN and OS, or is it done?
    Locate the \My Documents\EFILive\V7.5\Bug Reports\Upload_YYYYMMDD_HHMMSS.blx file and send it to me at paul@efilive.com. Include a link to this thread so I know what its about.
    Note:
    YYYYMMDD is the year, month and day
    HHMMSS is the hour, minute and second that you attempted to read the ECM.
    Jan 2006
    E-Mail sent... Although I forgot to reference this thread
    Got the email. Not good news though :(
    Junior Member Jared Duramax's Avatar
    Feb 2008
    Yup fried ECM from what i can tell from here. the same thing happened to me twice the first time i had to replace the ECM the 2nd time i was able to do a full system reflash and get it to work again.
    Jared
    2003 GMC Sierra 2500HD LB7
    285/75R16 BFG AT, Prodegy brake controller, Bilstine Shocks, Tierod sleves, Pitman and Idler supports, 5" Magnaflow Turbo Back, PPE Boost Valve, Phantom II Boost and Pyro on Pillar, BD Manifold. EFI LIVE V2 By SoCal, EDP Twin Lift Pump's, Suncoast IV 1056, Billet Input Shaft, Merchant Automotive Pump Rub Kit
    Member #3 of NC Dmax's
    Jan 2006
    Sent that ECM back and got another ordered... Can an 03 or 04 LB7 OS be loaded into an 01 ECM?
    Feb 2008
    No it must have the same OS as the original one
    Jared
    Actually, it can be done without killing the ECM (which TechII will do), but, I am not 100% sure that the other modules in the vehicle will like it.
    I remember this being discussed on DP a while ago and a few people did it no problem.
    EFILive Distributor Trippin's Avatar
    May 2004
    Late OS into early ECM seems to be happy.
    Early OS into late ECM, not so much.
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    Jan 2006
    The reason I'd want to load a new OS is I have an 01 ECM, but if someone had say an 03 or 04 LB7 and I was going to let them try a tune or something, best bet would be to flash their OS into my ECM, modify it and let them run that instead of trying to run with the 01 OS in their 03 or 04 truck.
  1. I can't read my pcm
    By BlownSierra in forum Gen IV V8 Specific
    Last Post: November 28th, 2009, 10:38 PM
  2. Please Read First
    By GMPX in forum Conversions / Aftermarket Parts
    Last Post: May 25th, 2009, 11:09 PM
  3. Can't Read TCM
    By ARK 99coupe in forum E37, E38 & E67 PFI ECM's
    Last Post: June 15th, 2007, 02:32 PM
  4. Read posts in search...read tut..LM1 help.
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: March 15th, 2006, 02:00 PM
