Results 1 to 9 of 9
Thread: inlet valve temp - dma pid not working
    Lifetime Member hymey's Avatar
    Jan 2008
    Default inlet valve temp - dma pid not working
    I have installed the lasted bootblock and firmware. I select connect to vehicle-e38. Record.
    It says inlet valve temp- dma not working. Please deselect. It was the only error displayed. Do I deselect in options ini or is there a problem with the bootblock/firmware..
    Also what steps do I take to deselect this pid. Option ini is on my harddrive and not my controller(efi explorer)?
    Hymey
    To de-select a PID:
    You can comment it out of the *PSL_LS2 section in Options.ini on your hard drive.
    Then use EFILive_Explorer to copy the modified Options.ini file back into the [Config] folder of the FlashScan device.
    I will look into why it thinks it is not supported. Can you please tell me the operating system number of your E38 controller? Each operating system needs to be configured differently for each DMA PID (yes its a HUGE job, glad Ross gets to do it and not me). It may that DMA PID was not set up correctly for the OS in your ECM.
    Jan 2008
    righto Paul, I will let you know tonight. I will mod the options file for the meantime and copy it to the config section on efilive explorer.
    cheers
    Joel
    Jul 2007
    Sounds exactly like the problem I had with APCYL_M on the E-38.
    I think something got changed with the latest update that has effected the E-38 DMA support.
    Simon
    Jan 2008
    Hey Paul,
    12619078 is the o/s in my car. Hope this helps.
    Joel
    Quote Originally Posted by hymey View Post
    Hey Paul,
    Joel
    Thanks, found the problem. All DMA PIDs on E38 were being reported as unsupported. Fixed in next update.
    Jan 2008
    Can I use the last firmwires option.ini e38 file? When is the release of the next firmware. Will get much more accurate ben factors using serial output rather than the EXT.AD1 analogue output.
    The next update will be posted today.
    Jan 2008
    Thanks Paul
  1. Valve Cover Vents and PVC
    By Rusty in forum Gen III V8 Specific
    Last Post: March 6th, 2009, 11:25 AM
  2. Intake valve temp -40
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: October 1st, 2007, 12:35 AM
  3. Varable Valve timing for L92 6.2L
    By 02Z06 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 28th, 2007, 11:54 AM
  4. Programming the Intake Air Valve for a Positive Air Shutdown
    By jpgmtech in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 20th, 2007, 01:38 AM
  5. Valve Bounce identification logging
    Last Post: June 1st, 2007, 01:01 AM
