Results 1 to 3 of 3
Thread: speed calibration v7.5
    Member Ritch's Avatar
    Feb 2007
    Default speed calibration v7.5
    notice for metric tuners the formula for H0101 should read
    H0101= P*D*100000 / ( T*pi)
    there should be 5 zeros not 6
    ____________________________
    1999 GMC, rcsb, 2wd, 5.3, XR275HR-12
    Radix magnacharger mp112
    Long tubes true duals, $L60E
    Unless my math has deserted me (and it does sometimes), the constant should be 1,000,000 (6 zeros, i.e. 1 million).
    That is because there are 1 million mm in 1 km.
    So an example calculation using a tire diameter of 640mm, a diff ratio of 3.42 and a VSS gear with 40 teeth.
    H0101 = (40*3.42*1,000,000)/(640*3.141592653)
    = 136,800,000/2010.62
    = 68,038.7 pulses per km
    If I've made a mistake somewhere, can you explain why you think it should be 5 zeros?
    The only way I can see it needing to be 100,000 was if you were measuring the tire diameter in cm.
    Feb 2007
    Yep that's what happened I used cm
    Sorry for the interruption.
  1. odd Calibration
    By CalEditor in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2009, 05:38 AM
  2. 02 LC1 calibration using V2
    By waterbug1999 in forum FlashScan V2
    Last Post: May 2nd, 2009, 10:14 AM
  3. Help with MAF calibration
    By dvx in forum General (Petrol, Gas, Ethanol)
    Last Post: July 5th, 2008, 08:37 AM
  4. V2 A/D Calibration - FAQ
    By Blacky in forum FlashScan V2
    Last Post: March 10th, 2007, 10:57 AM
  5. MAF calibration?
    By leres in forum General (Petrol, Gas, Ethanol)
    Last Post: September 5th, 2005, 01:22 PM
