Hi Guys,
I did this a few weeks back.
Just for those who may be interested in swapping to the 255 Walbro and can't find any info on it.
http://www.pacificp.com/forum/viewtopic.php?t=6878
Hi Guys,
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
Welcome Joe...if it helps someone out...great!
To date...no issues with it. I've run to just less than 1/4 tank without problem.
Actually...when I first put it in....it started and ran with about 2 gallons of fuel in the tank.
Howard
DUCT TAPE.
Man, you document things like a champ! Good werk.
01 C5 'vert A4
EFILive, PLX, & TNT are all we got at the moment.
i know this thread is old but i have done this modification aswell. and i recommend it over a complete sending unit replacement even for stock vehicles.
its actually quite easy, mines been running trouble free for a year, and the pump is not noisy IMO.
I used the GS342 Walbro and put a fitting in port to hook that line up to keep the bucket filled. I also re-used the accordian pressure line out, it fits over the pump outlet quite tightly, i then used a small clamp to retain it.
Lysholm supercharged 98 K2500 454
stumpuller454 welcome to the forum...
Welcome to the best tuning forum on the net 'Stumpy'.
Howard
DUCT TAPE.
Nice work.
I have the old Wahlbro that needs the bucket altered and
I've got to be careful taking corners with >1/8 of a tank of gas.
LC-1 WBO2
