Results 1 to 3 of 3
Thread: Can't display in metric
    Jan 2007
    Default Can't display in metric
    Hi All,
    well...ever since I swapped over to vista, I can't read my logs in metric.
    I've tried going to properties ad seting it to metric...no go?
    Any ideas?
    Howard
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Jan 2007
    Never mind....found it.
    Thanks Joecar!
    In scantool PIDs tab, right click on each pid and select metric or imperial.
    Howard
    Howard
    DUCT TAPE.
    Howard,
    Also go into the tunetool and edit the units configuration to set various tables and/or their row/col indexes to metric/imperial.
    Follow the first bunch of links from here: showthread.php?t=2990
    Cheers
    Joe
  1. Imperial vs Metric
    By killerbee in forum General (Diesel)
    Last Post: September 3rd, 2009, 09:16 AM
  2. Metric????
    By twinki025 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2007, 06:29 PM
  3. Dashboard switches to metric sometimes
    By Jakes4321 in forum FlashScan V2
    Last Post: June 8th, 2007, 05:37 PM
  4. scantool display to use as dash display?
    By ace68 in forum Lounge
    Last Post: March 3rd, 2006, 06:50 AM
  5. how to change metric to american calibrations???
    By HioSSilver in forum Tutorials
    Last Post: August 23rd, 2005, 05:58 PM
