Results 1 to 3 of 3
Thread: Injectors or fuel filter?
    Member Ritch's Avatar
    Feb 2007
    Default Injectors or fuel filter?
    Here's the tune on my 99 5.3 truck with stock intake and exhaust manifolds. Notice VE table over 100% after tuning with an LC-1. Are the original injectors so weak that they can't keep up with this flat cam? (stock) I have 2.5" pipes off the manifolds into a 3.5" collector and then 3" to the bumper. No cats. I quite sure the filter is good because my fuel pressure was steady at 58psi
    ____________________________
    1999 GMC, rcsb, 2wd, 5.3, XR275HR-12
    Radix magnacharger mp112
    Long tubes true duals, $L60E
    Ritch,
    In tunetool properties, change the VE table units to g*K/kPa, and forget about %...
    g*K/kPa are "normalized" units with no reference to static volume at at some given temperature (which is always different/varying than your running conditions)... you should be doing AutoVE using g*K/kPa.
    g*K/kPa shows that the VE table does not give "VE" but it gives airmass normalized for pressure/temperature.
    Oh, also be sure to set fueling units to AFR or EQ and not Lambda.
    Joe
    Feb 2007
  1. Fuel Filter Minder countdown strangeness
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 4th, 2010, 02:36 PM
  2. Fuel Filter
    By Shaftner87 in forum Duramax LLY
    Last Post: May 9th, 2010, 02:01 AM
  3. do injectors have an effect on fuel psi?
    By mr.prick in forum Gen III V8 Specific
    Last Post: June 6th, 2008, 03:25 AM
  4. LS7 Fuel Injectors
    By TAQuickness in forum Lounge
    Last Post: April 13th, 2006, 06:20 AM
