Results 1 to 10 of 11
Thread: knock retard
    Aug 2005
    Default knock retard
    can someone list all the reasons why someone might be getting knock? can a lean condition cause knock? any help would be greatly appreciated.
    Jan 2005
    Not sure if all the reasons can be listed :wink:
    Being too lean
    Bad Gas/low octane gas
    Oil
    Too much timing advance
    That's just off the top of my head
    Aug 2005
    oil is good, gas is good, spark is perfect. probably a lean condition then! tanks for the help
    Jan 2005
    Not so much bad oil, but getting oil in the induction system.
    What motor do you have?
    Nov 2003
    What year do you have? It could be false KR... You could also have a pipe hitting..
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Remembering your car is boosted, how much timing is the engine getting just before it knocks?. Have you logged the actual AFR's before it knocks.
    Compression ratio too high.
    Running too hot.
    Valve train noise.
    Aug 2005
    blown ls1 in an 04 gto, mafless, and tuning VE tables.
    Oct 2003
    Why do you say "spark is perfect"?
    What is your total timing at WOT? How much peak boost are you running? What is your static compression ratio?
    IF you are blowing oil into the induction (it happens a lot with blown applications), it will degrade the quality of fuel going in and create knock.
    Powerful take-offs (something our blown cars can have in the extreme) can induce lots of exhaust noise of launch. :x You won't even hear it over all the noise. Double-check for loose or banging exhaust.
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
    Aug 2005
    i do have a very loose pipe as i just put a new exhaust system on, how easy is it for that rattle to be mistaken for knock? thanx for your help and awesome setup!!
  1. How to map knock retard?
    By jorge in forum General
    Last Post: August 13th, 2008, 09:31 AM
  2. Knock Retard GM.KNKRET vs Retard Due to Knock GM.KR
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2008, 04:18 AM
  3. How do I log knock retard?
    By zapp168 in forum General
    Last Post: July 23rd, 2007, 09:32 AM
  4. Knock Retard
    By NAH in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 21st, 2007, 11:15 AM
  5. Knock Retard
    By NAH in forum General (Petrol, Gas, Ethanol)
    Last Post: January 29th, 2007, 07:29 AM
