Results 1 to 4 of 4
Thread: Wiring for Active Fuel Management
    Aug 2007
    Default Wiring for Active Fuel Management
    Does anyone have the pin outs for the E38 L76 Active fuel management? I've got the plug and wires and want to hook it up.
    Cheers
    Does your block support it? Its not just wiring it up, there are hard parts that have to be swapped as well. You probably know this, Im just reminding ya.
    And sorry I dont have your wiring diags :(
    Aug 2007
    I haven't had this particular engine apart but it has the connector at the rear and I have seen in another I did cam swap in that 8 lifters are different and that there are large solenoids under the valley, visible with the cam cover off. I was under the impression that to be an L76 it had to have the gear else it would be a L98??
    Here's hoping.
    Aug 2007
    Got it for anyone interested
    AFM connector position A goes to E38 C2-11
    AFM position B goes to E38 C2-9
    AFM position C goes to E38 C2-10
    AFM position D goes to E38 C2-14
    AFM position E goes to 12 volt ignition
    I'll be trying in 2 weeks when the vehicle is re-booked.
    Joel
  1. Active Fuel Management controls?
    By XLR8NSS in forum General (Petrol, Gas, Ethanol)
    Last Post: January 20th, 2011, 09:39 AM
  2. Replies: 2
    Last Post: December 19th, 2008, 08:58 PM
  3. Question about AFM (Active Fuel Management)
    By Hollis1 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2008, 02:30 PM
  4. Can I modify Active Fuel Mgt. with EFI Live?
    By Patrick G in forum E37, E38 & E67 PFI ECM's
    Last Post: July 27th, 2007, 06:51 PM
  5. Disabling Active fuel Management
    By taz06 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 30th, 2006, 10:25 AM
