Results 1 to 10 of 18
Thread: PCM Type and Protocol. Work in progress
    Feb 2008
    Default PCM Type and Protocol. Work in progress
    Hey this is the start of my list. I post it on this forum in a thread.
    PCM type list.xls
    Feb 2008
    Hey it looks like I cut out all the down under cars except a few 2007 cars.
    Sorry. I will try to edit them back in.
    If any one want to add to it please do. I like the TIS Disc #
    01-05 GMT800 ECM-TCM Comms is CAN (J1939), not GMLAN... 06-07 GMT800s are GMLAN. JustFYI (Otherwise I could make a 06 TCM work in my 04 easily). Dont see LB7's in there...
    Feb 2008
    I will look into that.
    Feb 2008
    E60 PCM or the P59?
    CalEditor, I appreciate you uploading these, but I fear these might be copyright documents, happy for you to put a link to an off site host.
    I'll be pulling them down directly off our server in 24hrs.
    Quote Originally Posted by CalEditor View Post
    E60 PCM or the P59?
    LLY's are E60, no clue what LB7's are. I should be able tell you when I get an LB7 ECM though. Like I said, I'm 99% sure the E60 uses J1939 for ECM/TCM/GPCM/FICM comms; IIRC, connecting the A40 GMLAN pins to the CAN bus crashes the bus causing all kinds if problems (Codes, no-start, floods, plagues, death and destruction); I could probably try it this weekend and see what happens... I've never done it, but someone else that has been tinkering with the A40 did.
    Edit: According to Mitchel Ondemand5, 2005 (and 2004LLY) Duramax uses a "SAE J1939 Serial Data Bus" (CAN) for the ECM, TCM, FICM and GPCM inter-module comms. Apparently, the Hybrid (If it exists) uses GMLAN for ESB/SGCM/EHPS/HCM/PCM comms.
    Feb 2008
    That should work better. It is all mine
    Thanks, as I said, happy for external links to exist, just not direct here.
    Feb 2008
    Default E77
    This is the E77 used on 07 and 08 Cadillac SRX with 3.6L
    It is a Bocsh
  1. Progress with headers
    By cmitchell17 in forum Gen III V8 Specific
    Last Post: January 31st, 2008, 01:22 PM
  2. RTACS Progress
    By Doc in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 9th, 2007, 02:29 PM
  3. Progress on my move to OZZ
    By caver in forum Lounge
    Last Post: June 7th, 2006, 10:39 AM
  4. Question regarding J1850 protocol
    By PSWired in forum General
    Last Post: June 15th, 2005, 10:53 AM
