Results 1 to 3 of 3
Thread: Allison LB7 line pressure adjust?
    Mar 2008
    Default Allison LB7 line pressure adjust?
    Can the line pressure of the Allison be adjusted by EFI Live? I want to get just a bit more pressure into 5th. Is it possible?
    If so, what tables would I need to adjust and which way. I am getting better at the ECM, but I am afraid to dig into the TCM without someones guiding hands.
    Thanks,
    Tony
    Sep 2006
    No Tony, it can't...
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
    Mar 2008
    Ok thanks. I found out on both DP.com and TDG.com also.
    Tony
  1. 4L80E line pressure
    By pullincrazy88 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 17th, 2010, 01:56 PM
  2. line pressure
    By dezzi in forum Allison 5 & 6 Speed
    Last Post: January 18th, 2010, 02:59 AM
  3. Problems with Line Pressure
    By goldbergv95 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 5th, 2009, 05:41 AM
  4. Line Pressure Oddity
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 8th, 2008, 05:22 AM
  5. Modifying TCC line pressure.
    By Joel_SS in forum Gen III V8 Specific
    Last Post: December 8th, 2006, 10:40 AM
