Results 1 to 3 of 3
Thread: How do I Change the dashboard from analog gauages to digital.......
    May 2006
    Default How do I Change the dashboard from analog gauages to digital.......
    Hi Guys,
    I was reading through GM High Tech and Performance and they had a good article on EfiLive tuning. They had the dashboard set up using digital gauges, which to me, would be easier to read at a glance than the round analog ones, especially when the car is starting to see boost and things start to happen pretty quickly! I know, I should be watching the road and concentrating on driving, but sometimes I just can't help myself!
    Granted, I'm not talking about actual digital gauges, but ones that look like digital gauges (LED numbers).
    Thanks for any help that you could give me!
    On each gauge do rightclick->Gauge Properties, and then click on the button that says "123"... edit anything else you want, then click on Save.
    May 2006
    Thank You! :cheers
  1. Digital Dash
    Last Post: January 5th, 2010, 05:44 PM
  2. Dashboard - change size of the range?
    By Wallyman in forum EFILive V4
    Last Post: March 31st, 2009, 05:32 AM
  3. Logging E38 Analog PLX AFR
    By Tre-Cool in forum FlashScan V2 BB Logging
    Last Post: March 25th, 2009, 03:19 AM
  4. Replies: 1
    Last Post: May 22nd, 2008, 10:52 PM
  5. FJO Analog Input AFR PID
    By heavyfoot in forum General (Petrol, Gas, Ethanol)
    Last Post: July 15th, 2006, 03:26 AM
