Results 1 to 2 of 2
Thread: Open Loop SD VS Closed Loop SD Advantages???
    Nov 2003
    Default Open Loop SD VS Closed Loop SD Advantages???
    What are the advantages of going either Open Loop SD or Closed Loop SD??? Right now I just went to Closed Loop SD. I know in open loop SD you are not using the O2's. You would probally want to leave the WB in all the time??
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Jun 2005
    Default Re: Open Loop SD VS Closed Loop SD Advantages???
    Quote Originally Posted by BowlingSS
    Bill
    If you want to dial in your part throttle better, the NB's might be more accurate around stoich than the wideband. Therefore, you could tune part throttle based off of STFT's (turn LTFT's off if with in +/- 10), which is what I did. Otherwise, just go open loop with the wideband and be done with it.
  1. How to REALLY shut of closed loop/ force open loop
    By Tomato in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 02:37 AM
  2. how to go from open to closed loop?
    By bifster in forum General (Petrol, Gas, Ethanol)
    Last Post: August 28th, 2006, 07:23 AM
  3. closed loop and open loop switching
    Last Post: July 10th, 2006, 07:56 PM
  4. Open/closed loop question
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 8th, 2006, 10:05 AM
  5. 3 bar open or closed loop setup?
    Last Post: September 6th, 2005, 01:17 PM
