The instructions, which I have copied directly from Readme_First.pdf and pasted below, say this:
"How to perform the initial update to boot block to V2.05.07
Select the FlashScan Upgrade Boot-block menu option using the FlashScan keypad
sequence: F4->F1->F4. You will be asked to confirm the upgrade process a number of times
as per the following screen captures.
Before the upgrade process can be completed, FlashScan will test the flash memory chip to
ensure it is operating correctly. If the flash memory test fails you will not be able to upgrade
your FlashScan unit. In that case, please return it to the place of purchase for repair.
BOOTBLOCK UPGRADE
Upgrade Bootblock
to V2.5.07?
Press [Yes]
BOOTBLOCK UPGRADE
The flash memory will
now be tested.
The test will take
5 min, continue?"
Press [Yes]
BOOTBLOCK UPGRADE
Flash memory test
SUCCESSFUL
Continue?
Press [Yes]
BOOTBLOCK UPGRADE
WARNING
Do not remove
power during the
upgrade process.
Press [Ok]
BOOTBLOCK UPGRADE
A successful upgrade
will be indicated by
alternate flashing
orange LEDs.
Press [Ok]
BOOTBLOCK UPGRADE
The upgrade process
CANNOT be undone.
Continue?
Press [Yes]
BOOTBLOCK UPGRADE
ARE YOU SURE?
Press [Yes]
BOOTBLOCK UPGRADE
IN PROGRESS
DO NOT
INTERRUPT
The upgrade process will take about 5 seconds to complete, then the screen backlight will be
turned off (the text will still be visible) and the two orange LEDs will flash alternately to indicate
dead-poll mode. Dead-poll mode means that FlashScan is waiting to be programmed with new
firmware.
After programming the V2.05.07 boot block, a license update screen will appear
IMPORTANT: The License upgrade will occur automatically (and only) the first time
FlashScan is booted after the new 2.05.07 boot block is programmed.
The license structures stored inside the device need to be upgraded. FlashScan will check the
license structures each time it re-boots. If it detects the old style license structures it will
upgrade the license structures. In that case, you will be prompted with the following
ATTENTION
Boot block has
been upgraded.
License will
be upgraded now.
Press [Ok]
LICENSE UPGRADE
WARNING
Do not remove
power during the
upgrade process.
Press [Ok]
If the license upgrade is successful you will see the following message:
LICENSE UPGRADE
Upgrade
Completed
Successfully
Press [Ok]
If you do not see the message above, the license upgrade was not successful. In that case
you must return FlashScan to EFILive for repair."
[Bold emphasis is mine.]
I did not see the license message, so I repackaged everything to return to Ira. But I've gotten everything back out and will try the firmware update as you suggest.
Jeff
