Results 1 to 10 of 15
Thread: Ok Yes Im A Dummy But..........need A Little Help Please
    Jan 2007
    Question Ok Yes Im A Dummy But..........need A Little Help Please
    switched from v7.4.2 build 622 to 7.5.3 build 36 and Im getting "error failed controller operation has returned to normal operation please retry operation.. Im thinking I jumped so far from 7.4 to 7.5 my v2 might need reflashing................anyone know?........if so what drivers?........thanks
    SDAVER,
    Welcome to the forum...
    When does it say that message...?
    Is the FTDI USB driver working correctly...?
    Did you flash V2 with firmware FSProg_V2_4_70.ffw...?
    I pm'd tech support, they will be a day or two.
    Cheers
    Joe
    Jan 2007
    it all worked fine on 7.4(and still does).................not sure what drivers im using.........but im pretty sure thats the problem...............it connects to the ecm or tcm begins to read then i get the error and then a aborted read statement and the then the countdown timer. thanks
    2006 CHEVY 3500HD 4X4 CCLWB DUALLY LBZ : 4" into 5" mbrp, bd manifold, FASS 150 lift pump w/2micron filter,EFILIVE(great tuning delivered at the speed of light by IdahoRob), Suncoast IV 1057 triple lock, airraid intake, Kennedy headlight harness, 285 revos, leveling keys, 12.5k warn with air compressor, DEI alarm w/ remote start and turbo timer, Diamond Eye downpipe, Fleece Performance Cheetah 70 mm turbo
    585 rwhp 1115 lbft torque @danville
    Oct 2004
    A change to 7.5.3 is recommended and will likely need the FlashScan V2 firmware to be updated as 'joecar' suggests.
    If you try again with the 7.5.3 release can you check for .blx files in your 'My Documents\EFILive\V7.5\Bug reports' folder which have a creation time matching your attempt and send them to support@efilive.com.
    Andrew
    EFILive Crew
    Jan 2007
    OK
    1. cleared efi usb devices via control panel
    2. removed 7.5
    3. downloaded the usb clean utility.....cleaned
    4. re downloaded 7.5 installed
    5. downloaded new v2 for windows drivers
    6. plugged up v2 via usb......installed new drivers
    7. got all excited thought I might have accomplished something today. plugged into truck same error.
    I know its something simple Im missing........cant see the forest for the trees
    Jan 2007
    bug reports sent.............thanks everyone
    Oct 2004
    The reports did not come through, just links to them. You actually need to copy the actual files and attach to the email
    Andrew
    EFILive Crew
    Jan 2007
    resent
    thanks
    In both of those *.blx trace file that you sent, EFILive was attempting to read the Allison TCM. Did you select the TCM to be read out?
    Jan 2007
    YES, same error for ecm or tcm.........7.4 still works fine
