Good info, any progress?
Aaron
'03 Z06 Corvette - The normal stuff...
EFI-101, EFI Advanced, EFILive-101
EFI University Evangelist
My biggest problem is I don't know enough about injectors.
The second issue I have is that there is next to nothing available in the way of info on the Bosch greentop 42lb injectors.
So...at the moment...with the help of people such as Justin....I'm just toying with my injector settings. I have noticed that the slightest changes to the voltage offset table can make you go full lean on decel without DFCO enabled.
Also...with the oddball L31 and van tune...it seems to be the only tune which utilizes table B4002. Every other tune I've looked at has that set to 1 across the board.
I've ordered a book on EFI tuning so I'll hopefully be able to get some more of this stuff to sink into my thick head.
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
I had a similar start-up problem and I solved it with changes to B3650. My V was already tuned very close to spot on and I didnt want to make changes. I am running OLSD as well. It was from a thread I read on a similar topic. Here is what my table looks like now.
1.000000
1.000000
1.000000
0.999512
0.999024
0.998047
0.996582
0.994141
0.989258
0.978516
0.960938
0.930176
0.930176
0.930176
0.930176
0.930176
2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
Check Out My Latest Tune File: HERE
So far I've dropped my min pulse width 50%...I don't see any differences or feel anything different in the way the vehicle drives.
Howard
DUCT TAPE.
Aaron
Aaron
4003 & 4004 are set the same. I haven't played with 4005 at all.
Howard
DUCT TAPE.
