Originally Posted by
Cougar281
Any ideas why the PSL below won't log or view RTD properly? It stops, starts, hangs, burps, drops values to 0 or *, etc. If I select the other PSL I have configured for LLY's, it logs fine and normally.
*PSL_LB72
;Node PIDs (pid1|pid2|...|pidn) Alarm (min:max:style:time*10ms:hold*sec)
PCM, RPM
PCM, VSS
PCM, FRPACT
PCM, FRPDES
PCM, FRPACOM
PCM, FRPADES
PCM, BALRCYL1
PCM, BALRCYL2
PCM, BALRCYL3
PCM, BALRCYL4
PCM, BALRCYL5
PCM, BALRCYL6
PCM, BALRCYL7
PCM, BALRCYL8
; Allison 5 speed
TCM, TFT
TCM, GEAR
