Hi All,
In my search for info on the Bosch (Ford SVO-Motorsport) 42lb injectors I came across some interesting info.
Apparently the Ford Lightnings don't use knock sensors. They're either unplugged or disabled in the tune (this is from the factory). The reason being the noise from the roots twin screw blower will cause the tune to pull timing via KR.
Any thoughts on this?
Howard
