Results 1 to 5 of 5
Thread: Electronic throttle control
    Oct 2006
    Default Electronic throttle control
    Tuning a 2008 avalanche and this thing is a dog out of the hole. Anyway to get the throttle plate open quicker?
    Remove Torque Managament, this has a huge affect on the throttle plate plus it will shift a ton better.
    Jan 2007
    im in the same mess as you dude-ive tried everything and only made it marginally better than stock
    i think its just a mechanical thing like camshaft that makes these things pigs down low-or maybe we need some more tables that are holding us back without knowing
    08 gmc sierra6.0 4sp-e38/t42 k/n intake
    4x4 ext cab
    You need to log spark timing and also the throttle position and blade (throttle motor) position. Otherwise you are just guessing as to what is holding it back.
    If you find the timing is reasonable and the throttle blade is fully open then it's not the tuning that is the problem.
    Oct 2006
    What ETC pid reports blade position?
  1. Ls1 pcm running electronic throttle
    By nathans1987 in forum Custom Operating Systems
    Last Post: October 5th, 2009, 09:58 AM
  2. Replies: 28
    Last Post: December 23rd, 2008, 01:22 AM
  3. Electronic Throttle Control warning code
    By ckJoshZ28 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 19th, 2008, 04:48 PM
  4. Electronic Throttle Control Error
    By racer383 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 27th, 2006, 12:00 AM
  5. Electronic throttle control conversion for the F-Body?
    By leres in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2005, 07:02 AM
