Results 1 to 4 of 4
Thread: Newbie question...
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    Default Newbie question...
    I got the software and have been reading on it. But, can some one point me in the right direction??
    The 1st thing I want to do it fix the cold start up issue. It will start briefly, then shut down. Ill try and re-start it but it just cranks until I start tapping on the gas pedal. Then, it will start to catch and eventually idle on its own.
    I know it WAY rich as I can smell alot of gas after it starts.
    What tables do I adjust? I saw the "crank/start" portion under the "fuel" section. Is that where I should start?
    This is for a HC LS1, if it makes any difference. Thanks.
    WB, welcome top the forum...
    You may need to do several things
    - recaculate/recalibrate your IFR table,
    - AutoVE and/ior AutoMAF tune,
    - idle tune.
    More info, see What to Tune First: showthread.php?t=7867
    What vehicle/mods do you have...?
    Joe
    Mar 2008
    - idle tune.
    Joe
    Ill read the link and re-think things. But, its very difficult to read and "try" to understand alot of it. What you just listed, I have no clue what that is or what it does. I just know what the car does and common sense would tell me the "start/crank" portion would be it, but I guess not. lol
    I have my tune uploaded on my lap top and now just trying to make sense what everything does and reading the definitions..
    I have a 99 Trans Am with 90/90, X3 cam, Dart 205's, FLT Stage V trans with a 4K stall and full bolt ons. also has a 100 wet shot I have been running as well.
    So, I am just starting the whole learning process and this cold start issue is pissing me off.
    Mar 2008
    - idle tune.
    Joe
    IFR, I am assuming means Injected Fuel Rate?
    I have FAST 36# injectors and an adjustable fuel regulator set at 60psi. but, to get my IFR from the excel spread sheet, it asked for the "injector Rated Fuel Pressure" and I cant seem to find that anywhere.
  1. Another newbie question
    By rbrtclk in forum General (Petrol, Gas, Ethanol)
    Last Post: April 18th, 2010, 04:16 PM
  2. newbie question
    By Baldric in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 06:43 AM
  3. Newbie with question.
    By WisconsinHick1 in forum Gen III V8 Specific
    Last Post: March 16th, 2009, 12:49 PM
  4. Another Newbie Question...
    By boating4five in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 17th, 2008, 09:47 PM
  5. Newbie Question
    By V7TTE in forum FlashScan V2 BB Logging
    Last Post: February 28th, 2008, 08:53 AM
