Results 11 to 20 of 34
Thread: help with P0420 please
    Dec 2007
    ya, i switched that on the tune i made after my last post...
    just pulled the P0420 codes out of it again today
    Im thinking the switching isnt actualy doing what its supposed to.
    possibly time for the EFI guys to check their code.
    Dec 2007
    oops, heres the latest tune
    does anyone from EFI actually read these forums for customer feedback?
    Well Im stumped man, Ive heard of people killing the CAT DTCs on I6s before so this is puzzling. Im still catted as I pretty much have to be in WA, so I cant go run and test it.
    EFILive does monitor the forums pretty regularly, just the P10s are GMs little bastard child and Im happy we actually have a way to tune them. I do have a wish list but the code is supposedly really hard to crack.
    Dec 2007
    Its hard to narrow down if its a mis-labeled switch as another member suggested, although the thought has crossed my mind, as it doesnt come up right away. Sometimes its taken a couple of days and several runs for it to show up.
    Sep 2007
    Default o2 sensor spacers
    I am going to try an o2 sensor spacer when it arrives......this is supposed to take the back o2 out of the stream a little.....
    In the Audi circle, people use spark plug defoulers(only on the post cat sensor) in order to trick the ECU when running a test pipe in place of the catalytic converter.think you have to drill the hole bigger on a defouler
    2003 TB EXT I-6 210,000 miles... Volant CAI.. NO CAT with magnaflow ..efans ...pcmforless tune and hotchkiss swaybar and air bags in back springs...new alt, pwr steering pump and water pump at 200,000 shooting for 300K or more
    Dec 2007
    let me know how it works out.
    Last time i cleared the P0420 code it went allmost a week before popping up again. The wife said she was flogging it pretty hard when it came up this time.
    This has me thinking if its related to the cat protection somehow....possibly the sensor is getting hotter than the computer thinks it should??
    My next step actually was going to be to just clamp the sensor off to the side of the exhaust pipe or the hanger and see if that helped.
    Sep 2007
    it has to be in the stream...already tried disconnecting it or hanging it to outside air connected
    Nov 2007
    Quote Originally Posted by ExtTB View Post
    Before having all the codes disabled in efilive i used one of the bungs they sell on ebay,
    http://cgi.ebay.com/ebaymotors/UNIVE...spagenameZWDVW
    they worked great, here's the list of codes i have disabled and NEVER got a code back, NEVER...
    >>>>> P0137
    >>>>> P0138
    >>>>> P0140
    >>>>> P0141
    >>>>> P2A01
    >>>>> P0420
    >>>>> P0054
    this disables all the monitoring of the 2nd o2 sensor,
  9. #19
    Sep 2007
    same thing but the place I ordered it from hasnt delivered...so maybe ebay is the way...bought th efans and pigtails from there
  10. #20
    Dec 2007
    Quote Originally Posted by pjaneiro View Post
    >>>>> P0137
    >>>>> P0138
    >>>>> P0140
    >>>>> P0141
    >>>>> P2A01
    >>>>> P0420
    >>>>> P0054
    check the tune i posted....i have all those turned off and still throwing codes
    if i cant figure a way to do it on the programming properly ill try something physical.
  1. E38 LTFT banks 1&2 differences and p0420 code
    By icetraxx in forum E37, E38 & E67 PFI ECM's
    Last Post: May 6th, 2010, 03:44 AM
