anyone know the proper setting to setup the LC1 for e85
? volts at ? AFR
and do you know what the voltage to AFR calculation should be changed to in the generic.sae folder.
? volts at ? AFR
I would also like to know.
Bill
2011 Camaro 2SS/RS L99 RJT
VMax Ported RJT Throttle Body
Gorilla Wheel Lock System;
i have been unable to connect to my wideband so i just used the same
.88333 V at 5 AFR
4.21667 V at 15 AFR
that it was already programmed for
the formula i came up with is
(Voltage * 2.999994000012) + 2.3500152999694
this will give you the correct e85 A/F but you wont be able to use the AutoVE BEN factor untill you change some settings because it still sees the commanded as 14.7, i have not had time to mess with it.
i just left it showing the A/F for gas (14.7) and just made sure it didn't go over 12.6 at WOT. 12.6 A/F for gas is the equivalent to 8.4687 in e85 which is max power lean for e85.
